Bit changes using Chilipeppr
How do you do bit changes in chilipeppr while making sure nothing moves? When the Gcode sends a bit change code to chilipeppr, chilipeppr gives me an option to give the motors full power to hold the motors, but I can still EASILY move the x & y axis around
The only reason I want to use chilipeppr is because of the zero touch plate widget. Is UGS better for bit changes? If there is a line of code for a bit change in easel, will easel stop for a bit change? I know easel has a lock motor function that actually works.
