Hi…I’m new here and l need help… l try to carve and cut plastic (HD-PE&PP) with all recommend bits but without luck? I need clean bottom surface!Where is the trick?!
20190917_175743|375x500
The most important factors are:
- Machine fully rigid on all axes, no flex.
- Spindle 100% in tram
- Large diameter bit, single flute
- High quality end mill, fresh and sharp.
- Low RPM and appropriately fast feed rate
You shed no light on your bit/rpm/feed rate data, please elaborate on that.
Agreed. The low RPMs are the key.
My suggestion would be to create a multi-toolpath with a handful of different shapes. Set each to a different feedrate/RPM and test on your material. Hopefully that will get you your appropriate feed/speed in one swoop. HOPEFULLY.
With plastics, you want the material to chip away, not melt. That’s the difference between high and low RPMs
Also, I know they make “flat bottom” bits for smooth pocketing. I can’t remember the technical “googleable” name. Anyone?
