What bit/s would you recommend to quickly create smooth pockets on machinable wax? The pockets range from 6"x6" to 12"x12" and about 1" in depth.
I plan to use 1/2" Carbide Tipped 2 Flute Straight for the rough cut and then a Fishtail Spiral for the clean finish. Will that work? I am a little concerned about the time it will take for the Fishtail Spiral to clean up that much space.
I think a standard end mill would provide the best bottom finish in a pocket.
Do you really need an 1/8 bit for your pockets?
If so just just use the 1/8 bit as a detail bit in a 2 stage carve.
