I cannot find my bullnose bits for cutting aluminum in my bit menu. It only contains end mills and v bits. I added them from the store but they will not show up in my bit menu. Help a noob out! thanks JJ
Bullnose or ballnose? If BALL, then those can only be used for 3D carves in Easel. If you want to use it anyway, knowing that the geometry won’t be exact, just use an endmill of the same diameter.
If BULL, you would use that just like a flat endmill, but Easel won’t take the geometry of the cutter into account.
Ok thanks!
