What´s the best way to do a squared box like a dice
I’m confused. a die is a cube. are you wanting to make a cube or a box for holding dice?
Can you post a photo of the desired end result or something similar, that would be a huge help understanding. thanks!
I ment a closed box like a dice
with all sides with the same measurements
it doesn’t have to be solid
There are box maker apps within Easel.
Select the Lego icon on the left side to locate the apps.
Search for “Box” and you’ll find the 2 box maker apps one with an open top or sliding lid, and the other “Box Maker Classic” makes 6 sided cube-like boxes.
