Hello puppies. Ok, I had to post this picture just for the padding. My girls love that it’s pink. Dad loves that it’s modular.
Hello 75 Volts.
So, I got two SDSK-2321S (for the X and Y) and one SDSK-2311S (for the Z). SD for step & direction, SK for stepper killer (that’s some ballsy marketing). Each model comes in 3 flavors: D, P, S (in descending order of max RPM and ascending order of max torque). Since I will be direct driving them below 2000RPM, I went with the S variety that packs the most toque.
Here’s the curve for the SDSK-2311S:
And for the SDSK-2321S:
Here’s the bigger one (SDSK-2321S) next to a Stepperonline 269ozin. This is super compact considering it also carries its driver on its back. The default configuration is a 3/8" shaft, but it can be ordered with a 1/4" too. I went with the former and also switched to 3/8"-to-10mm couplers.
The autotuning process with the final load (i.e. the spindle) took about 10mins per motor. In case something changes in the future (e.g. a heavier spindle) a new profile needs to be generated by the tuning process.
