Inventables Community Forum
Bump Stop/Corner Bracket Template
Hey guys, I just cut out a quick bump stop guide that could be combined together to make a corner piece as well.
Here is the Easel link if you want to check it out.
And if you didn’t know the distance between holes on the wasteboard on the X axis is slightly larger than the y:
X-Axis Hole Distance = 72.5 mm
Y-Axis Hole Distance = 70.8 mm
Hi Brandon, just wanted to confirm with you - are the hole distances you provided from the center of each hole or edge-to-edge?
Many thanks,
Tim
@TimothyWood1 Those are measured on center.
Thanks v. much, Neil. Feel free to use the rulers attached. Should work on any laser including GlowForge, and sets up nicely on the X-Carve Pro. Once fixed in place on your wasteboard just dial in your X-Y start position, and reuse it each time.
X-Carve Pro Bump Stop Imperial Decimal Ruler 10-8x20
X-Carve Pro Bump Stop Imperial Fractional Ruler 10x18 MADE FOR GLOWFORGE
According to the Inventables wasteboard drawings, the X and Y hole spacing is 75mm.
https://workbench.grabcad.com/workbench/projects/gcl5zpCuwqCXWLvYktLQBc-2IHvossNo37ycTOkzg6gREW#/space/gcojYwyy_VqboQQ-9hKBJrjS3zGaGuue8sfnqRNxGI9WQS/link/597315
My mistake, just realized this was the XCP forum :blush:
75mm for the 1000mm XCarve - the Pro has the weird spacings.
