Cables for the stepper motor
Anyone who knows the minimum area of the cables to stepper motor
I need new and can not find the same as the original here in Scandinavia.
I have switched to the x controller and need new cables
In the USA for the stepper motors I use 18/4 gauge (4 18 gauge wires in a shield) shielded wires.
18 gauge = 0.823 mm^2
For other wiring I used 22/4 gauge (4 22 gauge wires in a shield) shielded wire.
22 gauge = 0.327 mm^2
If you can’t get wiring that matches these sizes, get wires that are a little bigger rather than smaller.
16/4 shielded would be best. Or do 18/8 22/8 and double up. We do that sometimes for secured keypads that use the weigand protocol.
Hi
I use these:
https://m.elfa.se/en/data-cable-shielded-x0-mm-stranded-tin-plated-copper-wire-grey-cabloswiss-pfsk-4x0-50-mm/p/15569561?q=Pfsk+4x0.5&page=1&origPos=1&origPageSize=25&simi=99.0
i forgot to write stranded.
