Can not change position of drawing
I am trying to center a design. I have tried clicking the center button, it highlights but the drawing doesn’t move. I’ve tried clicking on other positions as well. Nothing happens. The drawing just stays in the lower left hand corner.
Think the center button only tells Easel where the bit is zeroed to xyz and where to start cutting. You can manually change project placement by selecting all and change xy positions. Hope this helps.
The radio buttons tell Easel where you want the X and Y values you are about to type in refer to. So click the centre radio button then enter the X and Y position values you want to centre your drawing on.
Doesn’t do anything about the zero position.
Cheers
Ian
Perfect. Worked splendidly. Thank you very much.
