I will be converting my Shapeoko 2 machine to an X-Carve. The Shapeoko has Nema 17 motors and the X-Carve will have Nema 23.
My question is: Can I use the 24V power supply from the Shapeoko on the new X-Carve with the bigger motors.Can it supply enough power. I’m talking about the 3.75 Amp power supply.
I’m not sure if this is correct answer, but you can get the X-Carve can come with either NEMA 17s or 23s and as far as I know it ships with the same power supply.
You have the original 90W power supply (the one that looked like a laptop power supply). That is really small compared to the 400W power supplies they now sell with the X-Carve. I think you would be much better off spending the $80 for a new 24V enclosed power supply.
Is it 3.75A at the 120VAC input or the 24VDC output? Seems strange that two different power supplies were being shipped. Mine is labeled AC Input 110-120V @ 4.8A and DC Output 24V @ 10A.
You really need to have at least 6 amps to power the 4 NEMA 23’s correctly. In theory all 4 motors combined are capable of drawing about 16 amps but they would never all be drawing max power at the same time.
Real question is: could the SO2 power supply give enough power to run one or two Nema 23’s? I’m thinking about upgrading X and maybe Z before diving off into both Y motors. Any thoughts?
