Cannot get my X-Carve started!
The serial monitor doesn’t show anything next to the “send” button or in the big box below it. It shows 115200 and “newline”. That’s it.
Ok, let’s re-flash the Arduino. Do you remember how you did that?
Did you select the “board” and “port” in the Arduino IDE?
I can look back in this thread and see how to do the reflashing.
Not sure what you mean by board and port.
Under the tools menu you need to tell the Arduino IDE which processor you are using and what port it is on.
So, under “board” you would select Arduino Uno (or equivalent) and under the port you would select which port the Arduino is on (COM3 or whatever it is on your machine).
yup, i see it. sorry. Arduino Uno and my COM port are selected
Ok, go ahead and re-flash the Arduino with version 0.9j of grbl.
crap. 150 posts and i can’t find how to re-flash it
Try this, I’m curious if it works on Windows 8 anyway. Just use the .hex file included in the .zip
When you checked the serial monitor, was the arduino running already?
nope, didn’t work. kept telling me that the batch upload could not be completed
yessir it was
@NicShimala
Ok, do this then.
Except load version 0.9j in stead of I
Here
ok, done
Can you now get the version number in console window when you start up the Serial Monitor?
this is what pops up
Grbl 0.9j [’$’ for help]
Great. Enter the $$ command and post the results here.
$0=10 (step pulse, usec)
$3=3 (dir port invert mask:00000011)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=320.000 (z, step/mm)
$130=290.000 (x max travel, mm)
$131=290.000 (y max travel, mm)
ok
Ok, things are looking pretty good.
If you have the ACME screw change $102 to 188.976
$102=188.976
i have the M8. didn’t upgrade that yet
Now try to run the Machine Setup in Easel.
