I am trying to import a SVG and then engrave it. I setup the material and the correct thickness. When I import the svg, it displays cutting through the material and I can’t adjust the depth setting. It doesn’t matter if I change bits or make the material thicker. Cut depth is grayed out. Here is the project, if this is the correct way to share it: Calendar
I’m trying to engrave it as a reversed image on the back side of a piece of clear 1/4" cast acrylic.
Thank you!
