Where does everyone buy their 1/32 carving bits from?
drillman1 on ebay
Im just wondering what you folks are carving with a 1/32" bit? I know you need it for PCBs but what else are they being used for ?
I use the 1/32" and 1/16" down cut bits (from drillman) on my PVC signs as my detail bit with every opportunity the design allows me to. This allows me to avoid easel pro and it cuts down on the time considerably.
I like the 1/8"straight two flute from inventables, I have not been able to source or find a 1/16" and 1/32" 2 flute straight bit.If i could I would surely be trying them. The straight bits do a better job cutting the PVC with Oramask on it. The down cut at times gives you some clean up to do as it wont clear the plastic in some ares that the 1/8" bit cant get to. The up cut peels the Oramask and gets pvc stuck in it so you cant use them.
@SteveMoloney Came across this one the other day.
Freud 1/16" (Dia.) Double Flute Straight Bit with 1/4" Shank (04-096) https://www.amazon.com/dp/B00004T7B2/ref=cm_sw_r_cp_apa_i_WvcPCb4XEEXPH
thanks Neil
