Hi,
Thanks for taking the time to read this … hard to put into words …
i want to turn the 3D model over and carve in into the graphite … so i can create a mould to pour into
any tips welcome .
thanks
Steve
Hi,
any tips welcome .
thanks
Steve
I have not used the 3d carving in Easel yet but i would say you would probably need to reverse the carve so it cuts down instead of up in a seperate program.
Can you share the STL here or send it to me in a PM?
hi … its for any stl …
i though the same … but the stls appear solid … so there is no carving in the inside … does that make sense … when you turn the solid model over and level it with the top … its all solid …
Well, I was going to modify the STL, but I can’t do "any stl’.
What are you casting?
Wayne is saying that you’d have to modify the STL in another program…I think.
that would be awesome . could you do a skull or something like that … i just want to see it can actually do what i want it to !. would be greatly appreciated !.
is there an easy way to make an STL 'skin" thicker then cut it in half ?
Cheers
Steve
Hi all,
Take a look at this YouTube for the concept. This is in Fusion 360 - which is free for personal use but has a learning curve!
The above video is for 3D printing molds, but the concepts are the same, noting that the CNC machine can only cut down, not on a 4th axis, so you may need to slice your molds in stages or halves. Also remember you may need to mirror your STL, depending on your needs for text etc.
