Carving letter
Okay here’s what I’m trying to do . Set up an object to be cut out but inside of it I want a set of letter carved out. So I import my object get it sized then import the letters into it and shop them as fill set depth yet it does not cut the letters. Can somebody tall me what I’m doing wrong
If you share your project, I’ll take a look.
ill share but not sure how
File -> Share
Share With Link
Copy link, hit save, paste the link here.
thank you have some 32 seconds coming have to wait till then thanks again man
Alternately, you could try a different font, or turn it sideways and cut it a little larger. Not sure what the finished product is intended to be.
Additionally, the 1/32" bit will take quite a while as you will be cutting a depth of .01" to .015" approximately per pass.
The way that I am finding it, the ‘detail pass’ will also do all cut outs and profile passes unless I am missing something? On a larger project this could become substantial.
I have question
hope someone can help me,
when i carved letter using vbit, why on the outside is not straight
sorry my english is bad
College…
I try Time New Roman and Swiss721 also like that, if using vbit 120 degrees worse
and when pocket letters are always like this
please someone help me…
this my vbit
MDF and Acrylic
vectric aspire
12000 rpm
feedrate 800mm/min
Looking at the tip from that angle in the picture, it looks flat tipped and not to a point, which would explain what Phil was saying.
It does look like your machine has some mechanical issues too. Loose Z axis, Vwheels, or belts. As Robert suggested, do a complete mechanical check of it.
i think machine no problem
whether the belt should be very tight ???
