Before I start this project, I would more info on how to set the router, (bit speed, type of bit and depth of cut), Any help will be appreciated.
Cutting Acrylic is best done with a single flute upcut bit (sometimes called an o-flute bit) and a slower RPM and faster feed rate versus when carving wood. this sometimes means using thinner passes depending on the cnc machine used and it’s frame design rigidity…
