hi i was wondering when you go from one tile to the next tile do you select use new position or last position.
Use last X,Y when tiling.
Hi SethCNC I got this figured out, but now I am having trouble with the material settings. When I put the size in which is 48" the last tile size comes up bigger than my work area.
Maybe the Work Area setting is not set correctly for your machine? Of due to the Overlapping effect the default tile count is too few, or the overlap is too much?
