Can someone tell me how to center (top to bottom and side to side) a text box in Easel Pro?
Many thanks.
Many thanks.
Just highlight what you want to center go up to edit click that and at the bottom it should say center to material. Just a heads up it will center it but it does center the box around what you have highlighted. You might look and need to move a bit to get it right depending on what you are centering.
Many thanks. I’ll give it a shot.
That seemed to work perfectly. The text was already centered in the box.
Many thanks.
i do not see center material when i hit edit. the last thing on mine is combine?
Not sure why mine has center to the material as the last thing under edit.
