Been having an issue the past week or so. I can not change my machine from inches to mm. Tried clearing the cache. two different computers. still no luck.
It should be 360 mm x 300 mm.
you should find this in the bottom lefthand corner.
That changes the workpiece. Then the machine has the following dimensions that i cant change. For some reason i cant make any changes to the machine at all.
The work area values can be typed in and then the “Save” button at the bottom selected to save those new values. Does this not save properly?
Hi SethCNC,
I have changed the work area multiple times and clicked save. But it always changes back to inches no matter what i do.
Youve got to flip the toggle to mm at the main screen. (Kens photo)
Then enter that edit machine page in order for the setting to be in mm units.
