HOW CAN i CHANGE THE BOTTOM PANEL for drawers to.25
You can’t - you have 2 choices - either making them (and the whole drawer) the same as the box carcass or making the entire drawer including the bottom out of one size.
I have brought this up here and put in a suggestion for it - A couple of design suggestions - #8 by WilliamHipple
The easiest work around is to make the drawer a different “material” and cut out all but the bottom, then cut the bottom out of what you want - not as elegant as the drawer height, but again with a table saw - not that bad to work around.
Thanks for the hint. I think I can change it in easel also.
I am extremely happy about this one…
Looks like this just got added to the “todo” list for updates - feature has been requested quite often
