Hi folks. I have been offline for a while. I just rebuilt my machine which was a centered gantry plate and now it is a moving Gantry system with a large cutting surface. (1000x1000). I have not made a new wasteboard but I am going form a 12x12 wasteboard now to a huge 30"? or so board.
So, I can can only think of using embeded T-slots or the screw system with the t-nuts .
What has been the most successful, easy to use in all of your vast opinions before I cut mdf?
I want to know what my best overall solution is!
Thanks for the great responses I know Ill be receiving.
“Poor man T-slot system”:
Take two layers of 1/2" MDF, Ply or similar.
Fasten one layer and run full lenght Y-axis slots with say 10mm width, 6mm deep, spaced 100 or 150mm apart.
Once done, glue the second layer on top and rerun the same program/path, but this time only 6mm wide / full depth (of the top layer)
Or basically achiebe the same thing doing this:
I use the tape and glue method. put tape on both the wasteboard and material, then glue one or the other. Place the material and place a small weight on it for 5 mins. What I don’t like about it is sometimes the pieces can be difficult to get off. The trade-off is I never have to use ‘tabs’ to hold interior cutouts.
material
blue painter’s tape
super glue
blue painter’s tape
wasteboard
Double sided duct tape. I’ve used it forever. Double sided cloth carpet tape too. No glue fumes. There’s a learning curve on how much to use, but you get the hang of it. This 2.5 x 20" fretboard is held in place by 3 strips 1/4" wide by the length of the board.
I have 1/4-20 inserts about every 6 inches too, but still prefer the tape over wooden clamps. Adjustability of the workpiece is easier with clamps though.
I appreciate the feedback guys! I’ve sucessfully used the superglue method. But I haven’t heard of double sided duct tape?
I guess I was asking more of different methods of peoples t-slot clamping methods. I will be making a lot of different items, and many times the glue method isn’t sufficient for me. Embarrassingly, because I had a very small wasteboard/gantry plate(and have been lazy), I have been using spring clips. It is time to move up from that archaic method.
My machine sits on a 40x40 piecve of MDf now and I have a 4x8 sheet handy just wondering if it is easier to cut and install t-slots, t-nuts form the bottom and or use movable clamps that way or other methods.
Wesley made an updated video recently if you are interested:
-Tom
