Very much a Newbie so asking for help. Have designed a Birthday plaque. Have combined all the paths. Now I want to edit an aspect of it. Is it possible to to uncombine my project to allow me to do this? If so the method would be very helpful. Thank you. Ian Streten
Only way is to use the exploder App, hope that helps. Or cover and area with 0 depth cut box and put the new on top of it.
You can also edit the individual points that the object is made of by double-clicking on the object, clicking on it and pressing the “E” key, or hitting the “Edit points” button on the object information pane.
It depends on what you want to change as to the route you might take…
{:0)
Brandon Parker
Thank you. Will investigate your idea.
