I am new to this forum and many thanks to everyone. I am also new to the fantastic world of carving. Actually, I am experiencing problems with the step motors of my CNC 3018 PRO. The fact is that when I connect the machine (that now I use as laser engraver) using Lasergrbl and I try to move the X- or Y- or Z-axis, just to check if there are issues, the motors seem not to move. I just hear a noise like something is moving, but nothing happen. What I observed is:
MACHINE TURNED OFF: I am able to rotate the motors and all the axes can move;
MACHINE TURNED ON: I am not able to rotate the axis;
When I adjust the feed rate, the problem still persists
the driver is installed because COM3 is the port which the machine can connect to the computer;
the same problem is shown when I use Candle
When I reset the motherboard, by pushing the button RESET, the problem still persists
When I re-install the driver, the problem still persists
Any comments, tips, advices are very much appreciated
Ok, all those look good, I was afraid that the settings were set so slow it was moving but at the speed of molasses…
One thing that could be the issue is the com port assignment number… sometimes windows doesn’t like 1-3 and reserves them for keyboard, mouse, and printer… so you can try a different usb port and that will change the number assignment, or you can go into device manager, the ports section, go into properties>advanced and then manually change the number to 4 or higher…
I’ve also found that restarting windows with the usb plugged in will cause windows to automatically locate the latest version of the driver and install automatically during the boot up… so you could try that at well
