I’m seeing that same log-in prob too despite already being logged in and able to post to the forum right now
Have you guys reported this?
Yes, I did report this awhile ago. Inventables just got back to me. Here’s their response:
The project isn’t publicly shared by the owner. There is a checkbox users can check if they want the project to be shared with the public. They would need to check that and save it. Here’s a screenshot (attached).
Unfortunately since this is a customer’s project, they are they only ones capable of making the project public. You might consider sending them a personal message to see if they can check that box.
Could you check the settings on the project?
Very nice work. My X-carve’s on order now and am enjoying all the great projects people have worked on! Thanks for sharing.
Oh believe me I am. Easel, Fusion 360 and more. Any recommendations are welcome.
I did see the check box and it is now checked. I got a lot of responses from the project. I don’t know how they could have gotten to see it if it wasn’t checked before so I am thinking it got changed some where. Can you see it now?
Yep, I can see it now. Thanks!
What’s add, is I use to be able to see it. I had it booked marked.
Getting an error when following the software link… The software is now hard to find. All the links I have found are not working.
Just use jason dorie’s halftoner, like phil said
while you’re at it, send the dude a beer via paypal…
does anyone know how to center the carving to the material? when i imported g code to easel it looks like this …
That’s not showing material in Easel when you import gcode, it’s showing the max range for your project. You need to set your origin/material size in the software you used to generate the code.
ok . I’m using halftoner 1.7, i noticed when i change the width to a certain number then go over to change the height , the program will change the width to a different number on its own. why is that ? example, i was typing in 11.75 for height and 14.75 for width of material. after i did that it changed on its own to something different . i didn’t know it until i went back to halftoner and looked .
Uncheck the box
wow! its that easy ! thank you very much
Hi everyone, I know this is an older topic but it seems I can’t find a decent “halftone to g-code” program for Mac. Can anyone help me with a working link ? looking for 3 days. big thanks and greetings from Belgium
I have been trying to download from Haftoner, a dot file is 2mb the same line file is 42mb. Neither will load into easel. Any suggestions
The larger files take forever to load the tool paths be patient it should load. The Marvel Aztec calendar took almost 50 minutes for me.
Works for me via safari on my iPad to view the project. This is pretty cool!
