I need help!!! I made a pattern by using the line drawing tool. is there any way to combine the lines so it is one continuous line?
Not within easel, no lines cannot be linked/combined.
If you export the project as a .svg (project>download zip, then unzip it) you may be able to combine lines using a graphics design software like inkscape or adobe illustrator, but Ive never done that, so cant really confirm tge best method.
Thanks Seth. I will give ink scape a try and see if I can achieve what I am wanting. once again Thank You.
