Connection problem
I Have a problem my new 3018 PRO made by YoraHome will not be found by my computer, I have only manage to get to part 4 “Machine setup” step 9’ This must have happened so often before someone has the answer. Please help, I have gone to much trouble to put the machine together correctly and can’t work out where I went wrong.
Most 3018’s will use Candle as the initial gcode sender.
Follow James’ startup playlist for the 3018 Pro Here:
Once you get it running through candle, you can move over to Easel, just know that only one controller can connect to the CNC at a time, so if you have an offline controller plugged in you can’t also connect to the PC. and if the CNC is connected in candle it can’t also be connected in Easel.
