How can I convert my 500 x 500 to a 1000 x 1000 machine.
you buy some maker-slide that is 1000x1000 and install them. you will also need longer belting on all three axis.
I would get the wide maker-slide for the X-Axis listed here
you will need two of these for the Y axis
https://www.inventables.com/technologies/makerslide
and also get extra belting (as in 4 meters) so if one breaks in the future you have plenty of extra
https://www.inventables.com/technologies/gt2-belting-open-ended
you will also need to extend your bottom extrusions to match 1000mm and make a new waste board.
https://www.inventables.com/technologies/aluminum-extrusion-20mm-x-20mm-black
and here is the technical drawing of the waste board it is just 3/4 MDF which you can get at any lumber yard.
If I missed something please add to this list.
don’t forget new longer wiring.
Invest in a good tap if the makerslide or 20x20 isn’t tapped.
plans for 1000 x 1000
