Using X Carve I made these stools, carving the seats out of some 'Merican walnut and the base from stacked plywood for strength.
The backs…so I made the forms on the X Carve then used a Roarockit to luthier the backs from 0.8 MM leaves and some curly maple veneer I had left over from another project.
There is a prize if you can guess what the base stringer is, the circular thing giving stability to the base.
Some sort of control wheel to turn and open valves or something?
They are beautiful!! My only suggestion is to cap or round off the through bolts at the base wheel. I say that because I am the type to squirm my feet around in there and probably scratch myself or tear a sock like the big lug I am.
