I’m trying to copy and paste an image in easel, but it won’t copy the image. It just keeps pasting the previous image i copied. How can i fix this?
I’m having the same issue and am also looking to see how to fix this.
I have not seen this but you may shut your computer down and restart it and see if that helps.
Had tried that without success
I got it figured out. I logged on to easel using the browser on a different laptop and the cut/copy and paste worked just fine. I logged on to easel using my original laptop shortcut and the cut/copy and paste also is back working. I have an easel short cut on my original laptop and using that to exit and re-login while the glitch was happening did no good. Try logging into easel using your browser vs any shortcut and see how that works.
