Hello, trying to use a core box bit to cut out names for tracing. The issue that I’m running into is that easel, it says there is nothing to carve? any ideas
thank you,
thank you,
Youll get that prompt when the bit is too large to fit the design, youd either need a smaller bit, larger font, or most likely a center line style font
but centerline fonts are not available within the easel font directory, youd have to do the stancil design outside of easel, then bring in the svg of the design.
