Hello, when I import an AutoCAD 2018 drawing with an arc or circle into Easel, the curve appears as a faceted line , or a series of straight line segments.
When I import the AutoCAD drawing to Aspire, and then export it as a dxf and then import that file into Easel, the curved line is nice and smooth !
Why is this so, in the words of Prof Julius Sumner-Miller
I’m looking for the same answer Joe. I found a couple other posts like yours but none seem to have any replies. Ugh
I figured it out. Select the shape/arc and hit the edit points button. If you click on the points on the arc, it will show that its a “straight” segment, so click and change it to a “curved” segment.
