I input a cut depth of 1/8 inch but the cut was closer to 1/4 inch. What did I do wrong?
if you used a probe, check setting, or try again manual with paper
Thanks Ken but what do you mean about checking the setting with the probe? Also, by manual with paper are you talking about setting the xy point - if so should the paper be hard to pull once the bit makes contact with the piece?
Thanks again!
