I’ve done a fair amount of searching on here and find a lot of info but not specifically what I’m curious about.
So in cut settings are three choices. Feed rate , plunge depth, and depth per pass. I plan on doing a lot of pine carving and I don’t see a setting and the stock settings seem slow but I don’t really know that at all.
What can I increase safely ?
Depth per pass is obvious explanation to me and I would think if it’s an eighth bit you should be able to go .125 per pass…same with a quarter bit… .25 per pass? Am I way off on this ?
And what does feed rate mean ? Speed? Can I increase ?
And plunge depth I don’t get at all.
Thanks guys.
