I am only recently noticing a strange thing happening in my Manual Cut Settings. When I change the Feed Rate, to 1200 (for example) and then start the Carve, my Feed Rate has changed to 50,250 (or sometimes even faster)
I have been double checking my feed rate before starting a carve, sometimes when I go back in, I can see the enormous speed and change it, but other times everything looks great (even after triple checking) but then as I start the carve the speed has once again jumped to 50 thousand plus.
It doesn’t happen everytime I change the rate, but I would say probably 70 or 80% of the time.
I do switch between Auto & Manual when I’m triple checking, so that I can see if it changes,
Why would this be happening?
