Got a new computer loaded Easel and drivers set Grbl added machine 3018 The cuts are backwards and upside down but can cut one letter and it is right. Any ideas as to why
yes, the $3 settings on your machine are incorrect. You could manually edit the setting using this chart, OR simply redo the machine setup and when it prompts you to test the axises direction, answer the questions appropriately, this will cause Easel to change the $3 setting according to those answers…
I will try reloading my machine they are moving in the right direction but I don’t remember answering those questions. Thanks
Installed the machine again and set the probe I still have to flip and the position of the cut is wrong
which axis is the wrong direction? and what is your current $3 setting?
