Is there a way to cut the handle only? I have a 12x24 board I want a handle on, but everything I find is a complete board. I literally want only the handle that way the bit isn’t running around the whole board just for the handle
You can use the line tool and make a path for just the handle or import an SVG of a handle you want.
Or create a path that is closed but doesn’t cut on the board only the shape of the handle
I"ve looked online for a svg but everything is more like making a template. How would I make the path?
Easel - cheese boards.html (10.4 KB)
Check your dm
Or you could download a cutting board with a handle you like and block out the board with a rectangle with zero depth pocket cut. All that cuts will be the handle.
Thanks will try!
Ya! Thats another way to make cool open shapes or make layers to a carve
