Hi! Brand new to CNC, but have some 3D knowledge. Tried the first project in Easel, worked great, but now I want to carve something I drew in Fusion 360. Watched different guides, managed to make the paths, export and import back into easel.
It looks fine when I simulate in Fusion, to the eye it looks fine in Easel, but when I go to cut it’s cutting in the air. Looks like it might be cutting the thickness of my material. In the air.
Maybe, while writing this, I just gave myself the answer…should I not set a thickness in Easel perhaps? Is that the extra height? Should I set material height to 0?
In Fusion360 your work zero must be the same as your Easel Home Position (Easel Work zero)
- This is defined in Fusion360->Manufacture->Setup->Edit-StockPoint and click on your work zero, for simplicity let it be lower left and top of material. (Right-click your toolpath Setup folder and choose Edit)
- Also under Fusion360->Manufacture->Setup->Edit->Stock set Top and Side offset = 0, they default to 1mm. Otherwise the carve will start 1mm above your work zero. (You can skip this step, now knowing that the first 1mm will be in the air)
Thank you! Currently my Stock Point was the lower corner, like in this picture. So moving this up should do the trick? Do I have to redo all my paths?
Nope. Same thing. Scary thing is that when it goes from Home to start of milling it’s pretty low. About 5 mm off the material maybe. Then it gets to the starting point, goes up ~30 mm, comes down to maybe 5 mm, then back up about 25 mm then it starts cutting air.
So if I would just somehow bring the whole operation down 12 mm it would make a big cut in the beginning, going from home to start of milling.
That stock point is good provided you zero of the spoil board, and if you zero Z on top of the material you will be air carving.
When initiating the carve the Xcarve will lower itself to its safety height (3.8mm by default) then traverse over to the X/Y start point.
Yes you need to redo the tool paths when anything within the tool references are changed.
I got it working somehow. I started over. I must’ve done something wrong with my tool paths! Thanks for your help.
