Been playing with cutting LP records. Clamp the center hole and lots of clamps around the perimeter, these things grab and flex. Here is the link to the file. LP CLock 2 | Inventables Have fun.
Thanks for sharing the file
What bit did you use to cut with?
I used a 1/8" up cut since this was a pretty open design. I tried a 1/32" pcb bit with the dewalt set at a 1. It just melted the vinyl and made for an ugly cut. With the 1/8" upcut bit I ran the dewalt at a 3. I still had fuzzies but they cleaned up with my pocket knife blade. Hope this helps. Try different bits, travel speeds, and spindle speeds I sure there is an even better combination out there. If I find it, I’ll post it here.
