Hi, I have an issue with my x-carve, every time it gets done cutting out the sign the bit doesn’t move up and cuts into my design. What do I need to do?
are you using easel? go to machine go to general setting.
Safety Height
0.15 in
Step Over
40 %
Origin Safety Height
0.15 in
Yes, using easel and those are the current settings
increase to .75 and do a test carve, to see helps.
Hi Kellie, is this a standard X-carve (if so Old or New Z axis) or is it the X-carve Pro?
Also, what are the grbl settings? (this can be found at the bottom of machine inspector, press Crtl+Shift+D to open that window )
