Cutting through tabs
My xcarve is cutting the tabs out correctly but on the final pass it cuts right through them. Any idea why?
More info would be helpful like what software it was designed in and how you sent it to the machine or if it was all done and sent in easel maybe share the project to take a look at it. I probably don’t have an answer for you but more info will help you get one.
Make sure you don’t have two of the same image on top of each other.
Thank you. I actually figured it out. I guess the vector I downloaded had two cut paths around the shape that formed a loop.
