Getting really frustrated with Easel 3D Pro. I just cut my 4th 3D carve failure. My very first one turned out fine. The rough carve turns ok but cuts all the way through without tabs most of the time. Then the final finish cut is a total disaster. Look at the picture and you can how inconsistent the cut is and some places it doesn’t cut at all. This one was done after recalibrating my machine a Silverback 6060. Every time make anything I measure all wood used with a digital dial caliper. So I settings up with accurate measurements
I don’t have clue what is happening. Reaching out to correct this issue.
Robert,
It seems like the picture has gotten lost in the worldwide web.
can you share your project?
Trying but can seem to load pictures from phone. Have used laptop
drag and drop
