When I have a carve set to carve to a depth of .08 it is now carving to a depth of .1. This causes any fine lines I’m carving to be too deep and they blend together. This is a new issue and I had not changed anything. I looked at machine settings and even went as far as to set up the machine again. The z-probe dimension is correct and all axis are calibrated and move the exact distance. I’m at a loss and probably missing something simple but I can’t see it.
Hey @RudyGruenke if you don’t get any good feedback here try reaching out directly to support (help@inventables.com) and we can get you working again!
