So I need some help here. I am stuck. I am wanting the flower design to be a raised cut just like letters would be.
How in the world would I go about getting this to happen? I am hitting my head on the wall trying to figure it out. I am sure it’s super simple but can’t for the life of me figure it out…haha…
you can use the offsetter app at 0.00 amount and uncheck keep original, and the ok… the delete the original, delete the outer square.
Set the petals to 0 depth and Pocket cut type.
If you need help further, you can share the project and I’ll show with your exact project…
So I figured out the invert. But in doing so it removes the square in the corner. I would like to keep the square and add the flower on top. Is there a way to do this??
So a raised flower on top of that box. See pic with the raised flower and in that pic and the ones posted above you’ll see the squares that I am talking about.
I think you’d need to add a square and then adjust the layers (Move backwards and move forwards) until the 0 depth flower is on top of the mid-depth square
So, the square/border would be at like, 0.1" cut, the flower would be at 0 cut.
Now, with that said, looking at your picture, your frame is just nothing, so you’d need to drag out some squares to fill in the transparency of your design.
