Detail pass and depth problem
I’ve been operating my x-carve for 4 years and am now encountering a problem with my z axis and detail pass: I upgraded my Z-axis last week… It was working fine until yesterday.
My roughing pass is consistent but when I switch to detail pass the depth gets more shallow as the carve progresses.
Setting up my detail pass: manual, use last position and resume the carve. I use the same bit because I am just cleaning up edges.
Hardware is stable, nothing seems loose.
I’ve gone into machine inspector to go over settings and everything seems correct based on the information I’ve seen on the forum.
Thanks for any suggestions!
Thank you for all the responses.
I’m having the exact same issue, and could really use some help as I’m loosing sleep over this. Have you tried changing the finish pass cut pattern? Do you also notice that no matter the orientation, the finishing pass seems to cut higher towards the end?
