Hi all,
I’m still a noob at this but came up with a process that seemed to work but the detail wasn’t quite right.
I know I’m doing something (or multiple things) wrong but I’m not sure where it is. I’ve used the easel generated gcode in a couple senders with the same results. This is the process I used to get where I am and the gcode is attached.
I’d appreciate some advice to clean up my mess.
Downloaded a simple logo (https://3.bp.blogspot.com/-ke0QbQqHtCY/WeJDIROqKbI/AAAAAAAAOgg/w7BbCYiDXGkHeEwBQliyg2O77mZ63WMWQCLcBGAs/s1600/Free%2BMini%2BCooper%2BLogo.jpg)
Pulled it into Inkscape and did a bitmap trace and then exported to svg
Imported the svg into easel and moved/resized for the material (MDF), 1/8" depth and 90deg v-bit I’m using
Exported gcode for use in UGS
Sorry about the rotation but the major bad parts are:
- Dots outside the perimeter of the logo (top of image/logo left)
- Outer circle has vertical lines on left and right instead of continuing the curve
- Legs of the “M” are screwy and there’s a notch out of the top-right “V” of the “M”
- “N” legs are straight
- Overall not a very clean job.
Mini Cooper Logo.nc (379.2 KB)
Thanks in advance.
