I have a 17 inch round wood that I want to carve, how do I set zero on it ?
I would find center and work from there
They do have circle centering tools which allows you to mark the center, I have one deigned here: https://easel.inventables.com/projects/l2Cmpx5mQtEwEUjdVkbKaA
See the videos and images in this thread for tips on this.
A fairly easy method is to draw a chord in the circle … say 8" across. Then draw a perpendicular line from the exact middle of that chord through the center of the circle. You can then repeat this a few times around the circle and where the perpendicular lines meet should be the exact center of the circle. I would recommend at least three to get a good reference.
{:0)
Brandon Parker
