When when preparing to cut the inlay using the “inlay generator” app, the tabs and the tabs options/box disappears when I try to change the dimensions of the tab. This is a new issue. Haven’t been able to figure out what caused it.
The tabs will disappear if you’ve selected more than on design element grouping, however the tab options do not disappear from this alone.
The tab options and tab do disappear if the cut depth is NOT set to full depth.
do either of these seem to be the case?
Yes, I was not at full depth cut. thank you
