I have got everything up and running and I’m slowly getting things calibrated and setup. I have some resonance in the Y axis and was wondering if other people are hearing the same thing. In the video I’m running 75IPM which is much faster than I intend to cut at but it’s just a test. The voltage on the Y axis is 1.678, I had to turn it up a little to keep from skipping steps.
I plan to install a couple of Y axis braces this weekend. Hopefully that will get rid of the resonance.
To my ear it sounds like things may be a bit stiff/tight on your y axis. double check your v wheels and especially check to be sure the belts arent too tight
check out the belt vid here:
I’m running a 48v quiet gut spindle and not a 611, so I’m not sure how the weight difference affects how things sound
