I came across this video https://www.youtube.com/watch?v=Q-Q1o16Ux-I
Anyone know how to set this up in Fusion 360 or Easel? The stumbling block for me is that if I am doing multiple passes how would this be calculated?
Prerequisits for āNoā-Spoilboard
So when preparing a carve, say for a 12mm thick material and you want to cut through:
This will ensure the full depth = precisely spoil board surface.
If your 12mm work piece is actually 11,2mm or 13,5mm thick (or vary) and you zero from an arbitrary surface point of this material, carved to 12mm can give you under/overcut.
I donāt really get that.
A wasteboard is meant to be wasted. Thatās why they are cheap replaceable pieces. Trying to āsaveā the spoilboard is evidently possible as this fine chap shows, but ultimately not all that useful.
The finish on the bottom of his cuts doesnāt look like they are all that clean either.
Save yourself the hassle, cut 1mm into the spoilboard and never have a failed cut because of an all-or-nothing setup.
thatās my opinion though.
I use a scrap piece of plywood under the project and cut it 1mm deeper. Easier to replace the ply than the fancy waste board.
How did he cut those eggs out without tabs, it didnāt look like glue or tape was used?
Theyāll figure it out. Especially when they are low on time and have LOTS of orders.
Set your wasteboard surface as -(stock thickness). The way I do it on through cuts (similar to Haldor):
Say Iām cutting a half inch (12.7mm) stock all the way through, I jog my endmill to the surface of the wasteboard and send G10L20Z-12.7
That sets the wasteboard as the full depth. It makes sense for your model to be slightly thicker, so you donāt cut too deep on the first pass if your stock isnāt perfectly flat.
Donāt look like he used anything except securing the sheet itself. First operation carve the design, the later stage do the thru-cut where hold down isnāt that important (for that design)
yeah for circular designs you donāt usually risk that much not using tabs. I do it often. I just make sure Iām in the vincinity when Iām closing in on final depth.
I donāt know, but I recently have been using the Superglue and masking tape method with great success:https://www.youtube.com/watch?v=3uTsQ3dYRrk
Iām guessing it was glued down, it just doesnāt seem to take any effort.
Yea, but it is a pain to replace. I donāt buy the inventables one, and have a bit of a custom machine. It is also super annoying to try to mill a PCB on a gnarly spoilboard. You have to surface the spoilboard in
