Any tips on the best kind of double stick tape ?
I tend to buy this at lowes. There is a bit of learning curve on how much to use, as too much makes it hard to remove the part and too little it can shift.
I used to use a double sided cloth carpet tape by manco, but they don’t carry is locally anymore. The duct tape can leave a residue that comes off pretty easily with acetone. I tried the tape and superglue once and wasn’t impressed with the overwhelming glue stench.
I prefer the Yellow Frog tape, it’s located in the paint supplies at big box hardware stores. The blue painters tape doesn’t seem to have enough “stick” to it.
I was using Gorilla glue in between the tape but it takes forever to dry so I bought the suggested Starbond CA glue and bought the accelerator spray, now it’s almost instantly stuck.
@JaneShepard I use the glue and tape method for almost all of my projects. You can look at many of my videos to see how I do it. In the description their is a code for a 15% discount code for the starbond glue. Why pay full price? Yes I am an affiliate. Maybe this will help get you started in the right direction Here is one video. Installing an Auxiliary Wasteboard T-Track (without the t-track) with Tape and Glue Method - YouTube
I got this same tape i use for routering templates. how well does it work with the x-carve? And have you tried it with aluminum?
Carpet Tape all daaaaaay long
I wouldn’t use double sided tape, like that, with aluminum. As the aluminum warms, the tape softens and the stick can move.
Use CA glue and blue tape.
Also a painter’s tape and Starbond glue guy…
